WRECKING 2007 2.0 TFSI - DSG Jetta - Blue
Hey all,
I have a most parts from a Jetta with a blown motor. The car can be registered and is not written off.
BWA 2.0 TFSI motor - Broken exhaust cam
$1000 DSG 6sp Gearbox ON HOLD
$200 17" wheels with tyres
$100 roof lining ( no sag - has been retrimmed)
$300 ECU, ignition, keys ON HOLD
$50 rear bar with sensors
$10 glove box -
$100 Alternator,
$10 coil pack each,
$40 right Rear Window Regulator,
$40 Right front window Regulator,
$40 left front window Regulator,
$40 each window motors,
$40 Air flow meter,
$40 O2 sensor,
$40 NOX sensor,
$10 Right Front shock
$10 Left Front shock
$10 Right rear shock ,
$10 Left rear shock ,
$10 each rear spring,
$20 each wheel bearing,
$20 each hub assembly,
$20 each window Glass,
$200 Stock dump with catalytic convertor,
$20 cooling fans
$20 small cooling Fan
$20 Engine Mount SOLD
$20 Gearbox mount SOLD
$20 windscreen Mirror
$20 left mirror housing
$10 right mirror glass SOLD
$20 right mirror covers SOLD
$20 each outer Door Handles,
$20 Right front Window Switch pack,
$10 Left front Window Switch,
$10 Left rear window switch,
$10 Right rear window switch,
$20 Clock Spring,
$10 Radio ,
$10 each Wiper Motor,
$10 Front Wiper Linkage,
$50 set 4 Fuel Injector,
$50 in-tank Fuel Pump,
$100 ABS Pump 1k0 907 379 AC,
$10 each wheel speed Sensor,
$10 each Sun visor ,
$10 Handbrake
$100 fly wheel
$20 tool kit
$10 Blinker Switch
$10 Wiper Switch
$50 Master Cylinder and brake Booster
$5 hazard light switch
$10 mirror switch SOLD
$10 brake pedal
$20 accelerator pedal,
$50 right Drive shaft SOLD
$50 LED tailight outer right
$50 LED tailight outer left
$50 Boot
$50 Bonnet ON HOLD
$20 Left and right front gaurds SOLD
Doors Bare with skin - $20 each (no motors, glass, trim, locking mechanism )
Right Headlight SOLD
AC condenser SOLD
Interior lights SOLD
Various interior bits $please ask
Parts available in Wollongong
email: ineedacarpart(at)gmail(dot)com or PM me.
Cheers!
- You may not post replies
- You may not edit your posts
Forum Rules
