Results 1 to 1 of 1
Thread: WRECKING 2007 2.0 TFSI - DSG Jetta - Blue
    Nov 2007
    NSW
    Hey all,
    I have a most parts from a Jetta with a blown motor. The car can be registered and is not written off.
    BWA 2.0 TFSI motor - Broken exhaust cam
    $1000 DSG 6sp Gearbox ON HOLD
    $200 17" wheels with tyres
    $100 roof lining ( no sag - has been retrimmed)
    $300 ECU, ignition, keys ON HOLD
    $50 rear bar with sensors
    $10 glove box -
    $100 Alternator,
    $10 coil pack each,
    $40 right Rear Window Regulator,
    $40 Right front window Regulator,
    $40 left front window Regulator,
    $40 each window motors,
    $40 Air flow meter,
    $40 O2 sensor,
    $40 NOX sensor,
    $10 Right Front shock
    $10 Left Front shock
    $10 Right rear shock ,
    $10 Left rear shock ,
    $10 each rear spring,
    $20 each wheel bearing,
    $20 each hub assembly,
    $20 each window Glass,
    $200 Stock dump with catalytic convertor,
    $20 cooling fans
    $20 small cooling Fan
    $20 Engine Mount SOLD
    $20 Gearbox mount SOLD
    $20 windscreen Mirror
    $20 left mirror housing
    $10 right mirror glass SOLD
    $20 right mirror covers SOLD
    $20 each outer Door Handles,
    $20 Right front Window Switch pack,
    $10 Left front Window Switch,
    $10 Left rear window switch,
    $10 Right rear window switch,
    $20 Clock Spring,
    $10 Radio ,
    $10 each Wiper Motor,
    $10 Front Wiper Linkage,
    $50 set 4 Fuel Injector,
    $50 in-tank Fuel Pump,
    $100 ABS Pump 1k0 907 379 AC,
    $10 each wheel speed Sensor,
    $10 each Sun visor ,
    $10 Handbrake
    $100 fly wheel
    $20 tool kit
    $10 Blinker Switch
    $10 Wiper Switch
    $50 Master Cylinder and brake Booster
    $5 hazard light switch
    $10 mirror switch SOLD
    $10 brake pedal
    $20 accelerator pedal,
    $50 right Drive shaft SOLD
    $50 LED tailight outer right
    $50 LED tailight outer left
    $50 Boot
    $50 Bonnet ON HOLD
    $20 Left and right front gaurds SOLD
    Doors Bare with skin - $20 each (no motors, glass, trim, locking mechanism )
    Right Headlight SOLD
    AC condenser SOLD
    Interior lights SOLD
    Various interior bits $please ask
    Parts available in Wollongong
    email: ineedacarpart(at)gmail(dot)com or PM me.
    Cheers!
