Results 1 to 4 of 4
Thread: Whiteline KTA252 alloy lower control arms - suits MQB cars (Tiguan/Golf/Octavia/A3)
    Brand new in the box - recently sold my car and never got around to fitting these lower control arms.
    Suits all MQB platform cars such as Golf Mk7, Tiguan, Octavia, Audi A3 etc)
    Complete Alloy arm with -0.3deg camber and +2.0deg caster correction
    $600 + postage
    Whiteline KTA252 VW Golf Mk7 Front Control Arm | Automotive Superstore | Automotive Superstore
    Feb 2014
    Any idea if they'd fit an Arteon?
    I've previously looked into the following Golf MQB lower control arms, but was told they didn't change the geometry much (if at all) on a Passat/Arteon: Harding Performance Lower Control Arms with DuroBall - VW Golf MK7, Audi A3/S3/RS3 8V - Harding Performance
    (+1 degree positive caster per side, up to 0.5 degrees negative camber)
    Any idea how I could compare these against the OEM lower control arms currently in my Arteon?
    These arms will fit the Arteon to the best of my knowledge, as its an MQB chassis car and these arms are supposed to fit all MQB chassis cars.
    The alternate ones you linked to are essentially identical as the ones I have, but made by another Aussie company called Superpro (and probably rebranded as a Harding Performance product). Its two different brands (Whiteline and Superpro) essentially offering the same product.
    Feb 2014
    Thanks, I'll have a think and do a little more research on the stock LCAs. The small weight saving and better bushings should at least provide a small improvement too...
