Results 1 to 9 of 9
Thread: White Dot Premium Bluetooth kit. MK6 Golf, Passat, Tiguan
    Apr 2008
    Comes with foam holder for under seat location.
    Brand new loom, with OEM microphone.
    $250 + plus postage to anywhere in Australia.
    May help install in your car for $100
    Feb 2009
    NSW
    Do you know if this will work with a mk3 octavia rs?
    Sent from my Pixel 2 using Tapatalk
    Apr 2008
    Quote Originally Posted by ozgti View Post
    Can you show me a photo of your cluster?
    Feb 2009
    NSW
    Here you go.
    Apr 2008
    It’s newer than White Dot.
    We can plug it in, code it and see if you like?
    Feb 2009
    NSW
    Premium is the one that reads texts? What else does it do?
    Apr 2008
    I've not seen any VW BT unit that does that.
    VW headunits with CarPlay or AndroidAuto will read out texts.
    This show pretty much what it does. Phonebook and all phone control from the headunit, as well as the cluster. It also has BT A2DP streaming
    http://www.myturbodiesel.com/wiki/bl...stall-and-faq/
    Feb 2009
    NSW
    Ah. I already have that. The 2011 multivan has the option of premium (text on the cluster and read out) but takes away the mobile data so you don't get emails whatsapp etc or normal phone which is just phone book call list and that's about it.
    Jul 2010
    I don't believe this will work with ur MK3 Octavia. It's electronics r MK7 Golf like.
    MK2 Octavia - yes, definitely will work.
    I installed a premium Bluetooth unit in my MK2 Octavia RS MY11 years ago. It was a 9WZ unit that works with the white maxidot/cluster.
    With an RSAP capable phone, it would work in "Premium" mode, where u can c and read text messages on the maxidot and headunit.
