Mk4 VF Engineering Dogbone with Delrin bushes (used) - $150 posted
Removed purely as I got the ECS performance billet dogbone recently. The VF mount was firmer and shifts were nicer. Delrin bushes were fitted < 1000km ago.
OEM Bosch B5 RS4, B5/6/7 S4 MAFs (used) - $60 each posted
Part number is 077133471K (VAG) or 0 280 218 067 (Bosch). Fits quite a few VAG models and is used on BT conversions retaining ME7.5. One is "descreened" which is popular mod said to improve flow.
034 Motorsport Billet MAF Housing (for above) (new) - $120 posted
Used for the Bosch MAF housing above, more info here:
https://store.034motorsport.com/maf-...ct_tabs_review
I paid $95 USD + shipping and it's new and unused.
4"/100mm MAF housing (for Bosch sensor) (new) - $120 posted
This is a universal MAF housing for high power builds. It uses the Bosch MAF sensor and has the flow straightening mesh to improve laminar flow over the sensor.
Fuelab 82823-1 Fuel Filter (new) - $200 posted
828 Series In-Line Fuel Filter with 5" Element
Long Length
Filter Element: 75 micron / Stainless Steel
-10AN Inlet/Outlet
Black
Russell Twist Lok 8AN Push-fit Hose (3ft) (new) - $30 posted
Boxed and unused.
Russell Twist Lok 6AN 90 Degree Fittings (x4) (new) - $25 each posted
Russell Twist Lok 8AN 90 Degree Fitting (new) - $25 posted
Same style as above
Russell Twist Lok 8AN 45 Degree Fitting (new) - $25 posted
Same style as above
Russell Twist Lok 8AN Straight Fitting (new) - $20 posted
Same style as above
I'd do a deal on the hoses and fittings if someone wanted the lot. The hose and ends are designed to work together (same brands). Pickup is available from the North Shore in Sydney.
