Page 4 of 19 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 184
Thread: R8 Coil Pack group buy from ECS
  1. #31
    Final GB items arrived today and will be shipped out to everyone tomorrow.
    I'm not sure if I'll run another one of these GB's this way again as the $ was dropping in the middle of everything.
    Too much stress having a fixed price up-front and then hoping the exchange rate holds up for 2 weeks....
    Anyway when I've recovered from this lot and if there's enough interest I'll place an order and then advertise the GB price once I know what the landed cost is going to be.
    With the $ keeping on going South, the good times are about to come to an end I think....
    I've just hit the button on another shipment of R8 coils.
    Anyone wanting a set please PM me - they should be landing in around a week.
    Cost is $125 pick-up/drop-off in Adelaide or $140 shipped Australia-wide.
    Jul 2013
    Ardeer
    hey Tigger will these be suitable for a 3.2 v6 passat 4 motion ?
    I'm not 100% if these will fit the Passat 3.2 v6.
    If you can check the part # for one of your existing coils you can probably check if this is the same as in the 2 litre motors.
    I'm told that these won't fit into an R32 but not sure if this is the same motor in the Passat.
    Sent from my iPhone using Tapatalk - now Free
    The coils used on the V6 engines are different.
  6. #36
    Nov 2007
    I'm interested if these will fit the TSI Amarok. Since my Amarok is 2 weeks away from delivery, I can't see to tell.
    I assume all the 2.0TSI engines use the same though.
  7. #37
    Jul 2013
    Ardeer
    Quote Originally Posted by stranger2502 View Post
    Read boy.
  9. #39
    These definitely fit in the mk5/6 2 litre GTI and R motors. So Tig 2.0, Octavia RS, Jetta 147 etc which use the same engine will work fine.
    I wouldnt assume anything.....especially being a VW. They may well be different (and hopefully they are because the stock ignition coils are rubbish and prone to failing - so in your best interest it would be good if your Amarok had a new design).
