Results 1 to 4 of 4
Thread: Pelican Case 1610 - Brand New w/ Foam
    Aug 2011
    St Kilda, VIC
    Thumbs up Pelican Case 1610 - Brand New w/ Foam
    Hi Guys,
    I have just moved and I have a brand new Pelican Case 1610 (with wheels) in black with pick and pluck foam. I have 2 others of these and I love them.
    I am in Melbourne and have a car so can meet within a close area if required.
    more information can be found here: 1610 Large Case With Foam | Pelican | Equipment Gear
    This sells for $450 from the shops, but not looking for anywhere near that, hoping to get about $200. Some pictures and details below:
    Watertight, crushproof, and dust proof
    Easy open Double Throw latches
    Open cell core with solid wall design - strong, light weight
    O-ring seal
    Automatic Pressure Equalization Valve
    Fold down handles
    Stainless steel hardware and padlock protectors
    3 level Pick n Pluck with convoluted lid foam
    Personalized nameplate service available
    Lifetime Guarantee of Excellence
    Retractable extension handle
    Strong polyurethane wheels with stainless steel bearings
    Specifications:
    Exterior Dimensions (L x W x D) - 63 x 50 x 30.2 cm
    Internal Dimensions (L x W x D) - 55.3 x 42.4 x 27 cm
    Lid Depth 5.2 cm
    Bottom Depth 21.8 cm
    Total Depth 27 cm
    Weight with Foam 10.12 kg
    Weight without Foam 8.85 kg
    Buoyancy Max 54.4 kg
    Range Temperature -40 / 99C
    No. of Wheels 2
    if needed you can contact me on 0422474593 for more info or questions.
    Cheers All
    MkV (2007) Golf R32 | Black | Fully Standard - For now!
    Jul 2011
    NEWCASTLE NSW
    for all those exocit arms/ drug dealers out there.
    Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
    ... and here I am in WA
    09 Polo GTi "Elke" | APR DV1 | H&R 35mm | Bilstein B8 | Remsa Pads | Pioneer |
    Nov 2006
    Largs Bay, S.A.
    Sent you a text. Not sure if you received it - did you sell the case?
    Cheers.
