for all those exocit arms/ drug dealers out there.
Hi Guys,
I have just moved and I have a brand new Pelican Case 1610 (with wheels) in black with pick and pluck foam. I have 2 others of these and I love them.
I am in Melbourne and have a car so can meet within a close area if required.
more information can be found here: 1610 Large Case With Foam | Pelican | Equipment Gear
This sells for $450 from the shops, but not looking for anywhere near that, hoping to get about $200. Some pictures and details below:
Watertight, crushproof, and dust proof
Easy open Double Throw latches
Open cell core with solid wall design - strong, light weight
O-ring seal
Automatic Pressure Equalization Valve
Fold down handles
Stainless steel hardware and padlock protectors
3 level Pick n Pluck with convoluted lid foam
Personalized nameplate service available
Lifetime Guarantee of Excellence
Retractable extension handle
Strong polyurethane wheels with stainless steel bearings
Specifications:
Exterior Dimensions (L x W x D) - 63 x 50 x 30.2 cm
Internal Dimensions (L x W x D) - 55.3 x 42.4 x 27 cm
Lid Depth 5.2 cm
Bottom Depth 21.8 cm
Total Depth 27 cm
Weight with Foam 10.12 kg
Weight without Foam 8.85 kg
Buoyancy Max 54.4 kg
Range Temperature -40 / 99C
No. of Wheels 2
if needed you can contact me on 0422474593 for more info or questions.
Cheers All
MkV (2007) Golf R32 | Black | Fully Standard - For now!
Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
... and here I am in WA![]()
09 Polo GTi "Elke" | APR DV1 | H&R 35mm | Bilstein B8 | Remsa Pads | Pioneer |
Sent you a text. Not sure if you received it - did you sell the case?
Cheers.
