Dutch do you know if these clear BBK's?
I know a few people have had issues in recent times...
For sale are almost brand new OZ Leggera HLT gloss black wheels in 19 x 8.5 ET38 5 x 112 fitment
Offers around $2,500 ex freight ($3,700 rrp)
Wheels were fitted for under 2,000km but car is being moved on - my loss, your gain
Pics on my Audi below, any serious buyers I will take pics of the wheels directly or post these up once off the car next weekend
Will they fit Mk 7 GTI ? without any HC rings etc ?
OZs come in a 66m CB only for VAG so I've always run HCs on my Golfs and now RS3 with no issues.
Fitment on a Mk7 GTI I think would be marginal on a stretched tyre/stock suspension, you'd want to have some camber in there to tuck.
I have OZ on my GTI without HC rings, + 44 no issues.
I understand some people choose to run without them, it's a simple metal ring sitting in the centre hub which can be removed if not desired for any reason. I've just always run them to get to the 57mm fit.
There's plenty of hub rings on ebay. You can get plastic ones or aluminium. Both will work/do the job. The OZ's should have come with hub rings if you bought them new otherwise both OZ and HRE will have a 66mm CB for their 5x112 bolt pattern and put hub rings in if you're fitting them to a VW as opposed to Merc/Audi which is 66.6mm.
I didn't realise they were so cheap - a set of 4 for $3: 4 Hub Centric Rings 66.6mm to 57.1mm | Hubcentric Ring 66.6-57.1 fit for AUDI DA | eBay
Or get the alloy ones: 4Pcs Wheel Hub Centric Rings Spacer 66.6mm OD to 57.1mm ID Aluminium Alloy | eBay
These were just the first 2 that came up but just search for hub ring and 57.1mm to 66.6mm and you'll get a ton of options. There people that stock these in Australia for $20-25 but sometimes the shipping from China isn't much slower...
