Brake Set from 2018 Arteon R-Line. Calipers, 340x30mm Rotors, Brake Lines, Guards and Pads.
AFAIK - these are the same spec as Golf R brakes, but unpainted and without the faceplate. Happy to be corrected if wrong.
Plenty of thickness left on the aftermarket pads, but replacements are recommended - they rattle a bit over deeper ruts (VW inspected and found pads to be poor-fitting, but safe), pad brake sensor wire was also cut during replacement.
Price: $550 ono
