Hey mate, how many k's on the turbo?
I can't move in my garage so time for a clean up!
If you are after something else not listed, please ask.
All parts available for pick-up or If item able to fit in Aus Post pre-paid satchel, happy to post at buyer expense.
All parts sold as-is, shown in photo. I also have a box of nuts, bolts, gaskets etc. to go with some stuff as long as you know what it goes with.
GTI front brakes (Calipers, Rotors + Stainless Steel Braided Lines) $249.99
Need new pads.
GTI OEM Down Pipe $99.99
GTI OEM Cat-Back $99.99
(OEM Turbo-back $199.99)
Cat in good condition.
APR 3" 'J-Pipe' (Fits K03+K04) SOLD
GTI OEM Intercooler + Piping $69.99
K03 Turbo $299.99
GTI Engine Cover + K&N Filter installed (OEM filter also incl.) $199.99
Intake ducting missing a screw and broken near missing screw. Cover is fine.
GTI Tail Lights (Outer Left, Inner Left & Inner Right Only) $49.99ea
Rear fog-light & reverse light lenses are in LHD configuration as I bought R32 lights from Germany and swapped with them. Easy to pop lenses out and use your own.
Outer Right has a permanent fog on inside I can't remove?
GTI Halogen Headlights Pair (Incl. Bulbs) SOLD
GTI Fuel Injectors $49.99 (Set of 4)
GTI Underdrive Pulley + Belt (Belt 6 Months Old) $19.99
GTI OEM Suspension $199.99
GTI OEM Turbo Discharge Pipe $19.99
Hey mate,
Are those headlights exactly the same as any mk5 lights, just with halogen bulbs?
Are those springs a few mm lower and stiffer then standard mk5?
How many ks on the springs?
Are you willing to ship the headlights?
Are the headlights glass or plastic??
Interested in the J pipe PM sent
08 Octavia vRS Manual|DNA Stage 2 Tune|Golf R Intercooler|APR DP|Carbino Intake|Uprated DV|Porsche Calipers (NQSBBK)|Superpro Alloy front control arms and bushes|42DD Stealth Catch Can and PCV|42DD Shift Bushes|Whiteline adjustable rear sway|Superpro torque arm bush| Front and rear lower strut braces|Whitline steering rack bush|
