list your part numbers as often the parts will cross over to other VW product. Rear brakes seem to be especially variable.
For those of you with 288mm front brakes, you can use these rotors & pads to do a GTI upgrade using your existing caliper. All you need is caliper carrier 1J0615125 5N0615125 3C0615125 1K0615125 (the 0615125 seems to be the important bit). You can get them for about $140/pair + post off ebay
Possibly / probably these will work
Disc Brake Caliper Bracket Service Plus Caliper Bracket Front Left Right Cardone | eBay
Definately these will work
Audi A3 8P 312mm Caliper Carriers 5N0615125 1K0615125C Octavia MK2 Golf MK5 | eBay
