Results 1 to 8 of 8
Thread: MK5 GTI or Jetta 2.0T brake rotors and pads
    MK5 GTI, Jetta 2.0T or Tiguan brake rotors and pads
    I have a recently purchased set of front and rear rotors and also front and rear brake pads for sale. After ordering these i have taken a different direction with the car so will be going to bigger brakes front and rear.
    The rotors are Fremax brand and are often spoken as being a great upgrade from the factory discs, due to the high carbon content. The front rotors measure at 312 x 25 vented and rear rotors are 286 x 12 solid.
    The pads are from Remsa and these are regarded highly on this and many other forums for a great daily pad but also good for the "spirited" drive. They are rated to 650 degrees but produce less dust than OEM and also less rotor wear.
    These cost me $436.20 less than a week ago, looking for $360 ONO + postage, but prefer pickup.
    Located Northside Brisbane
    Erskineville, NSW
    list your part numbers as often the parts will cross over to other VW product. Rear brakes seem to be especially variable.
    For those of you with 288mm front brakes, you can use these rotors & pads to do a GTI upgrade using your existing caliper. All you need is caliper carrier 1J0615125 5N0615125 3C0615125 1K0615125 (the 0615125 seems to be the important bit). You can get them for about $140/pair + post off ebay
    Possibly / probably these will work
    Disc Brake Caliper Bracket Service Plus Caliper Bracket Front Left Right Cardone | eBay
    Definately these will work
    Audi A3 8P 312mm Caliper Carriers 5N0615125 1K0615125C Octavia MK2 Golf MK5 | eBay
    You have a PM
    Pm Replied
    Aug 2009
    Are these gone?
    If not I'm Interested.
    (I'm northside Brisbane too)
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    Pending at the moment.
    If sale falls through i will let you know audi-tone
    Aug 2009
    No worries mate
    Brakes sold thanks all
