PM'd you re the IE TIP mate!!
IE Silicone TIP, as new, never opened $150
AGU (big port) inlet manifold, freshly bead blasted, with a repair to the rightmost lower mounting bolt boss $75
VDO Siemens AGU DBC throttle body 06A133063F with approx. 10k use. This is the cruise control version that was replaced (hence the relatively new condition) after I started getting idle problems. $150
Standard AGU fuel rail with 4 bar FPR 75$
4 off Siemens DEKA IV 660cc injectors, used for 600kms before I swapped out to an IE inlet mani/fuel rail/longer injectors $225
Damn I would have been interested in that TIP as well.
08 9n3 Polo GTI
Mods: heaps
mate I just need to know if its an 80mm at the top to accept a 3in MAF?
its 2 3/4 inch at the MAF or 70mm.
