Results 1 to 5 of 5
Thread: MK4 1.8T IE Inlet pipe/big port inlet mani/660cc injectors/fuel rail/DBC TB c/control
    IE Silicone TIP, as new, never opened $150
    AGU (big port) inlet manifold, freshly bead blasted, with a repair to the rightmost lower mounting bolt boss $75
    VDO Siemens AGU DBC throttle body 06A133063F with approx. 10k use. This is the cruise control version that was replaced (hence the relatively new condition) after I started getting idle problems. $150
    Standard AGU fuel rail with 4 bar FPR 75$
    4 off Siemens DEKA IV 660cc injectors, used for 600kms before I swapped out to an IE inlet mani/fuel rail/longer injectors $225
    nsw
    PM'd you re the IE TIP mate!!
    Nov 2012
    WA
    Damn I would have been interested in that TIP as well.
    08 9n3 Polo GTI
    Mods: heaps
    nsw
    mate I just need to know if its an 80mm at the top to accept a 3in MAF?
    its 2 3/4 inch at the MAF or 70mm.
