Hi simon
Is this fit Scirocco R?
Send me part number i will check KW web site
Hey Guys,
The GTI is getting put back to standard so the go fast bits have to go. For sale is a set of KW V1 coilovers from a MK6 GTI. Pretty sure they fit MK5 platform too?
Only travelled about 24,000 easy k's so basically still ride like new. Looking for $1000, will ship at buyers expense.
Simon
Forever blowing bubbles.
Hi simon
VW Scirocco R Viper Green/DSG APR Stage2+ APR RFD APR RCS t 42D Catch can Supaloy LCA FK Coilover KW DCC Canceller BSh Pendulum Neuspeed Dischargepipe CTS ICIFG4 19" black DBA T2 Rotors Remsa Pads Goodridge SS line Dunlop Sportmax GT CTS Turbo Intake R8 Coilpack TyroBCSk Spoon Rigit Collar GBF DV Whiteline Endlink Ult Racing Braces Unibrace UB ST2 DSG Velo Racing Seat Rear Adj. Toe arm Throttle cont.
I've been told by my mechanic that they do. Don't have the part number sorry. Will see if I can find out for sure.
Apparently they will fit but the spring rate is slightly different (hence the part numbers are different). I think the Golf is a little heavier? But all the mounting points are the same, so I'm told.
If someone else could jump in here and confirm that they fit it would be much appreciated
Yes, I believe you'll face difficulties with the spring rate...
Too stiff or too soft?
$1000 anyone?
I told myself I wouldn't do this again...
But I think the GTI and Cabriolet use the same suspension setup... I might have to have a look and see if it does...
You must! LOL Can meet you at Goulburn if that makes it easier.
