IDF drop plates suitable for mk1s 2s and 3s.
Mount between rear beam and hub for 35mm or 65mm of drop, with 2 degrees of camber.
Includes all bolts for various setups.
Purchased second had and only used for 6 months without any trouble. Sold my mk3 so they're no longer required.
Happy to post, PM me for a quote
$200 ONO
IDF's description:
"These CNC machined Drop plates reposition the stub axle on the rear beam giving the rear of the vehicle either a 35mm or 65mm drop, depending which configuration they are installed. They also add 2 of camber to the rear wheels. With the plates installed, a lower ride height can be achieved while maintaining maximum suspension travel. This will also put the rear beam at less of an angle, positioning the rear wheels further back and closer to the center of the wheel arches. Grade 10.9 mounting Hardware and Loctite 243 packets provided.
Works with drum or disk brakes, with or without ABS on either level of drop.
The 2* of camber is designed to offset the thickness of the plate leaving the top of the wheel within 5mm of its location before installation.
Bolt on installation requires removal of rear wheel bearing.
Bolts securing drop plates must be torqued to 47 ft/lbs with supplied loctite applied to clean threads.
Fits ALL Mk1, Mk2 and Mk3 Golf/Jetta"
SILVER '98 MKIII GOLF GL // BORBET TYPE A's
YELLOW '76 B1 PASSAT LS WAGON
WHITE '07 MKV JETTA 2.0 TFSI
FLICKR
B u m p
FLICKR
