Integrated Engineering billet vent to air catch can with all fittings needed to have a plug and play kit.
Cam cover already has the AN10 fitting so the hoses from catch can fit. Block breather replaces ****ty OEM plastic one that is known to crumble - this kit can help you easily delete the PCV system = no more worrying about vacuum leaks under there.
Includes everything you need for fitment next to the wiring loom tunnel. All you'd need is to blank the port on the TIP where the hockey puck used to be.
Selling because this is now a restriction on my setup.
More info on hardware:
https://www.urotuning.com/Integrated-Engineerin…/iebaca4.htm
Will fit any mk4 1.8t, maybe polo 9n3 + audi s3 & TT MK1
$250
