Quick update for those not following the support thread, many bigger issues have been resolved and in my view there are just 3 issues left that I want resolved before ordering the units, these are:
1. SD / navigation running at the same time causes a conflict where SD music playback may stutter / song switching may take excessive time. Some optimisation of the SD decoding will be required to fix this issue.
2. current method of SD music loading will always start from the beginning and take 15-20 seconds to load a ~4 minute song, though playback starts once ~30 seconds have been loaded. The issue here is if the song memory is at something like 3 minutes on startup, or you just started a song and want to skip to 3 minutes. The issue is more pronounced if you have a larger file / longer song. A different method of loading the song will be required to fix this issue (e.g. one that is able to load the song from whichever point rather than from the beginning every time).
3. navigation volume and SD volume have a conflict sometimes reducing the SD volume - this is due to navigation using the system volume same as SD, and should be an easy fix just by switching navigation onto a separate volume on its own.
