Mines pretty good too. Fast, sound quality is excellent and fairly big free. I haven't updated the software yet either.
Man, calm down.
Everyone that currently has a unit put their hands up and asked for a preproduction unit. We knew what we were getting. No one that currently has one was expecting it to be release quality.
The issue was that Sandy got the group buy going when AS first started development, they had only just started. Product development takes time, and final specifications tend to change as the scope changes and as development goes on.
It's not a 'farce', nor an 'unmitigated failure'... it's just not done yet.
The software, in its current form, i'd call a beta, to be honest. 90% of it is there, there are just some minor tweaks and things to fix and change to hone it into a release ready product. If you look at the list of bugs (minus the ones that are caused by hardware issues, which Sandy has said he will replace), then it's pretty obvious they're just software bugs. Give it a few months (accounting for jan/dec being the lowest productivity months of the year) and it will get there.
As I said, calm the **** down, and if you don't have anything productive to add, stop posting.
Eh? No idea what you're on about. Sandy is running an even earlier unit than we are.
MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
See my post above.
Everyone was asked months ago, you can have a buggy, preproduction (but final hardware) unit sooner, or you can wait until the software is finalised (in the new year).
Everyone that currently has one right now KNEW THAT THEY WERE GETTING A PREPRODUCTION, HANDASSEMBLED unit.
There was no bait and switch or anything untoward. We knew.
Thank you for everyone's support - and apologies for not making an appearance yesterday.
Big thank you to all that contributed to the spreadsheet - I really should have done all this myself but I just haven't had the time lately.
I will make a new thread in the VW Car Audio and Electronics section with all important information linked in the first post this weekend. The problem with this thread is that it's in the Parts for Sale section and I don't think it's meant to drag on this long, and the first post is near its character limit (those URLs are lengthy...)
I do need to clarify on the bug spreadsheet though - I need to sit down and go through it all properly over the weekend. Many issues in there are related to the CAN-Bus instability which was fixed in the later firmware. Several are duplicates of each other, and more are isolated incidents that may be related to the pre-production hardware build. The rest are mostly either minor issues or feature requests. My own sample unit has been running fine and I wouldn't hesitate to show it off to any passenger.
In other news, there is new firmware available:
https://dl.dropboxusercontent.com/u/...CU20131217.rar
I don't think this one focused on many bugs - I just sent the latest Google spreadsheet to the software engineer and it is a little overwhelming at first glance. There is no BSP update yet, just MCU and MPU. But the upside is, there is an updated UI, and IMO it looks amazing.
I haven't had time to do a thorough test but I have noticed a couple of little improvements.
By the way I've noticed after a full firmware flash the BT is maxed out at full volume. There is a bit of noise at full volume but that's normal - dial it back to about 30 and you should be fine.
I expect to have some response from the software engineer regarding a few of the bigger remaining issues with the software later in the week.
Thanks for the update Sandy. Just loaded it and it looks good. It fixed the iPod charging issue! Woo.
Versions went to:
BSP: MS9E
MCU: DNS810.131217
MPU: 9005AS.A9.20131214_1
Shouldn't the volume across all modules be universally set? I find it strange that you can set the volume independently for Radio/SD/BT etc. It just seems strange. They should all be the same.
Also, what's the deal with the mirroring module?
Do you plug in a USB cable into the module, or into the DNS itself? and for iPhones, does plug into the already existing 30pin connector, or do you use a different cable? and what's the compatibility with lightning cables/iOS7?
Just did the update. The text the radio buttons seem a bit clearer, I'll have a good play tomorrow. Thanks Sandy. Love getting updates.
Sent from my LG-E975K using Tapatalk
No it allows for different volumes because the volume between different sources can vary - one of the issues with the old ANS series is that DVD volume is very quiet, SD / USB is about normal and Radio is a bit loud - so switching between sources, especially back to radio after watching a DVD, was a big scare. Having different volumes fixes that problem, the volume for each individual source is remembered so it will be at the right volume when you switch.
The module connects to the back of the unit, and the USB / iPod cable goes from your phone into the module. See the image below:
edit: just been told you will need the Apple official AV cable (I believe this is the one Audiosources is referring to) to connect to the mirroring module. I've asked for full details to be provided to me tomorrow. Just to clarify that image above is provided by Audiosources so I don't have the module to look for myself.
You must have left out the MCU update - remember after the MPU update and rebooting the unit back into radio, insert the SD card again to update the MCU.
