View Poll Results: DNS unit group buy - discount options
Voters
123. You may not vote on this poll
  • raffle for free units according to number of orders
    56 45.53%
  • split the price of the free units between all orders
    67 54.47%
Page 155 of 181 FirstFirst ... 55105145153154155156157165 ... LastLast
Results 1,541 to 1,550 of 1806
Thread: Group Buy / EOI new generation DNS head units (RNS-510 alternative)
  1. #1541
    Milton, Ontario
    Quote Originally Posted by kwalsh24 View Post
    To me, the issue isn't with the screen itself, bit perhaps almost with a processor, perhaps the video processor, as the system reacts to various things, ill turn the system off to get rid of the glaring white screen, just to have it turn back on when I put the car into reverse.
    Sent from my SGH-I337M using Tapatalk
    Excellent point. Mine is the same way. However the reverse camera white screen is much more colorful and ONLY happens if the turn on white screen happened then cleared with soft reset. Sandy something to make note of.
  2. #1542
    Dec 2012
    The latest firmware definitely hasn't fixed the memory issue. I still cannot use the SD playback and nav at the same time without severe stuttering or a complete melt down. During just SD playback (nothing else on) I have had several monsun.exe errors and it is tking an increasingly long time to load it every time you switch it to SD mode. Hopefully the coming update provides some fixes as I believe the SD module has some serious flaws at the moment. I can use the nav with any other mode with no issues at all although I can't test aux or usb till Sandy sends me the cables.
    Sent from my GT-I9305 using Tapatalk
  3. #1543
    Gr233n Guest
    Hi all.
    I have a couple of DNS810 units on order for my Mk6 Golf and my 2011 Caddy Maxi van. In my Caddy, I am replacing a stock RCD210 which does not have multifunction steeling wheel button functionality.
    Assuming I have the correct steering wheel with blank panels for the multifunction buttons, does anyone know would I be able to fit steering wheel buttons and have them work with the DNS unit?
    What would I need to do or have for the Multifunction display (between speedo & tacho) to provide the same comprehensive trip info as the Golf and also info from the DNS unit. Currently the MFD only provides very basic trip info.
  4. #1544
    Jul 2013
    Caulfield, VIC
    Quote Originally Posted by moda View Post
    Unit lights are triggered by the headlights. They have to be on.
    Fascia covers the gaps, google image what the rns510 in either a golf or skoda looks like and you'll see.
    It's pretty self explanatory, but yea, the book is useless. GPS attaches to the threaded port, fit the antenna where appropriate. The top of the unit has a pinout for the iPod/whatever. Radio antenna fits in the only one it would fit in. CAN harness fits in the only one it would fit in.
    GPS file is in iGo -> Scroll to bottom using your finger swipe, it's the only .exe file.
    Thanks moda.
    What's happening with the dns lighting is that it only comes on when I switch the lights on manually. I leave my lights on auto 100% of the time, and the dns does not realize they are on. So I have to flick them off and on again.
    I went to skoda for the fascia and the one they had was the wrong shape for my climate section. He could order a few different types in but it would take three weeks and weren't guaranteed to fit- no clear picture... Nothing about the gap filler inserts. Do you have part numbers for these inserts?
    In igo I'm looking for a way to silence spoken directions, while spoken alerts still exsist. i.e. turn left @ xxx is silent, but speed camera @ next intersection is spoken. Couldn't find this option.
    Thanks heaps!
    Sent from my HTC One X using Tapatalk
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
  5. #1545
    Pretty happy with the seeking through large mp3s speed now, it skips straight to it (even if you skipped 1.5 hours in from the start) and the screen is pretty response. Works well. There still is the bug about not remembering/resuming on shutdown/startup, though. It just starts from the start of the track (bit annoying for a 2 hour set).
    Quote Originally Posted by Gr233n View Post
    Hi all.
    Have a search around, theres some threads talking about updating a non MF steering wheel to MF. You need to get a new steering wheel and the modules to read them, I think it's a bit of a mission, from memory.
    On the MFD side, there's not much else that the DNS displays, so far. As discussed previously, eventually it should get updated to display nav and 3 line info for music etc.
    Quote Originally Posted by MountainBikeMike View Post
    Thanks moda.
    Thanks heaps!
    No clue what's going on with the lighting, maybe try doing a reset.
    No clue about the skoda thing, like I said, google golf rns510 and have a look, I imagine it should be similar or the same?
    In iGo, go to options -> Sounds and notifications, and have a look in there, there are all sorts of options for spoken alerts/directions etc etc, it's just a matter of having a play around and tweak it to how you want it.
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  6. #1546
    Cleaned up the spreadsheet a bit, removed some duplicates and added a Category section so it documents whether it's a bug or a missing feature.
    https://docs.google.com/spreadsheet/...Gc&usp=sharing
  7. #1547
    Had a weird error tonight, exited GPS and the screen went haywire....
    Also no CD text support? Really? Mark that down for a requirement!
  8. #1548
    Jun 2012
    Adelaide, South Australia
    I thought the same about the CD text thing. But if u go hit menu. Then back to the CD screen the text comes up. But doesn't progress to the next track. This needs work. It seems that it recognizes track names etc. But doesn't realize to read the new one when the track changes. Should add it to the spreadsheet.
    Sent from my galaxy spaceship
    Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
    -MK1 Golf The re-spray/re-build
    In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
    A pattern seems to be forming...
  9. #1549
    New issue, my SD playback audio levels Have significantly decreased, 40 volume level is about 20-25 volume level on FM or cd
  10. #1550
    Jun 2011
    I'm still waiting on the new firmware, I should get it early next week.
    Audiosources has located the cause of the white screen fault, apparently one of the resistors on the motherboard did not like low temperatures. It's been fixed in the production unit. They are still investigating the memory and monsun.exe fault. It's a bit hard because the software engineer says he has not been able to replicate the problem. Also, monsun.exe is simply the SD playback program, so the fact that this program is crashing doesn't really help with tracking down the cause. Woweriux you said you can pretty much replicate it on demand, could you please explain how and if it's connected to a certain file / file type etc being played in SD mode?
    In summary, if you get excessive noise / static in the BT interface or the white screen error, these are likely hardware faults. I need to confirm availability with Audiosources but you will be able to exchange your faulty unit for the final production units. I will cover half of the return shipping for international orders and all of the return shipping for local Australian orders. The replacement unit shipping will be free per the standard warranty.
