View Poll Results: DNS unit group buy - discount options
Voters
123. You may not vote on this poll
  • raffle for free units according to number of orders
    56 45.53%
  • split the price of the free units between all orders
    67 54.47%
Page 150 of 181 FirstFirst ... 50100140148149150151152160 ... LastLast
Results 1,491 to 1,500 of 1806
Thread: Group Buy / EOI new generation DNS head units (RNS-510 alternative)
  1. #1491
    Milton, Ontario
    Quote Originally Posted by Goobz View Post
    I am still unable to run the SD playback and the Nav at the same time without the music playback severly stuttering, or that memory leak msg appearing that I posted earlier. I am on the latest firmware revision and have tried a reset.
    Also no one really answered my question about the air con pop up info. I was of the understanding that when you change something it pops up on the screen for a few seconds. Does this work for anyone else? I dont get anyting when I change a setting.
    Looking forward to that next revision update!
    Sent from my GT-I9305 using Tapatalk
    I am not sure if the AC info pop up is car model specific (ie MK5 vs MK6 vs Jetta) but make sure you go into your Menu, System (I think) and there should be settings for the amount of time it displays...perhaps this is set to 0 seconds or something??? I am not in my car so can't remember what the exact menu is....system or general I think....
  2. #1492
    Dec 2012
    Quote Originally Posted by swyner View Post
    Mine was set to 5 secs by default. I tried all the other settings but still nothing. I have a Mk5 GTI with the budget half height MFD so that might be the issue but it would be nice to get a bit of clarification as nothing was said about any model specific limitations earlier.
    Either way the memory leak issue is a bigger issue for me at the moment. Its strange my unit is the only one experiencing it although others have reported issues with the SD playback module so it could all be related. I want to test the USB input and see if it has similar issues but I need to get one from Sandy first.
    Hopefully the new firmware addresses some of these issues.
  3. #1493
    Milton, Ontario
    The other thing I came across when searching for Aftermarket "OEM" units like this was for the AC controls to work on the display, it had to be a dual climatic control system (ie left and right separate temp settings). Sandy, maybe AS has some info on this.
  4. #1494
    Quote Originally Posted by Fanaki View Post
    ^Ah fair enough, I'm still hanging tight to see how all this pans out as I want the unit. I had to ask, I like a good dummy spit every now and then haha
    Sent via OBD2
    Yep, someone please post a video review!
    TIA
  5. #1495
    May 2013
    Yep. You need the Mk6 Climatronics unit to make it do this. The Mk5 Climatronics unit is not capable of displaying the data.
    We are talking full climate control and not just A/C. Take a look at http://www.bold-sport.com/store/inde...product_id=149 they have the unit plus the new fascia surround to make it fit. They also have some pictures of which units can be upgraded.
    I believe you need to change a pin out on the harness for Mk5 to make it remember the temperature it was set at after you turn the car off.
    MY08 Mk5 GT Sport - sold
  6. #1496
    Dec 2012
    Ok that makes sense now. I have the dual zone climatronic unit but not the upgraded mk6 one. Thanks for clearing that up!
  7. #1497
    Oct 2012
    Hmm, it works in my 2009 jetta.
    Sent from my LG-E975K using Tapatalk
  8. #1498
    Oct 2012
    Oh, one other tip. If you get a monsun.exe or other freeze~ if you press in both dials, it does a power off in which I can turn back on unit without key pull.
  9. #1499
    Dec 2012
    Quote Originally Posted by Mister Jim Lahey View Post
    TIA
    Theres really nothing more to show over what Sandy already has in his videos. All the same functionality is there and the known bugs are well documented here.
  10. #1500
    Dec 2012
    Quote Originally Posted by Fdandy View Post
    Thanks for the tip Fdandy!
