Hmmm I'll have to try this, my unit said it updated in the info screen, maybe it only did half the update
Sent from my SGH-I337M using Tapatalk
Sandy. A slight correction to the above. If you load all the files from your zip file on the SD card and run the process it will delete the MCU file after it runs the MPU update. You have to remove the SD card and delete all the files and add just the AS...mcu.hs file by itself and insert into the gps slot and reboot the unit. only then will it update the firmware. I know it worked only after this because my MCU file shows 1202_CAN
To summarize (and Sandy this is from an earlier firmware upgrade email you sent):
1) Extract the entire contents of the .zip file Sandy linked above.
2) copy ONLY the UPD file to a blank SD Card. Do not include any of the files...just copy the one over by itself
3) Go back and copy all the other files EXCEPT the A9_MCU_iap.hs file. This would include the logo.bmp, MPU.ms, NANDINFO, PQ.bin and xip.bin
4) Insert this into your DNS while its powered off. Turn on DNS. You will get the colorful screen described above and picture same as kwalsh (and yes, the NAND error thing I get too...hasn't given me a problem)
5) Let it go through the process and as Sandy said above it will eventually say MPU success and it will reboot automatically. Take out the SD card before it reboots.
6) You should go through a screen touch calibration then it will boot to the radio.
7) Take that SD Card and remove ALL the files on it and then copy over ONLY the A9_mcu_iap.hs.
Put the SD card back in....unit can be on or off and I have had it work both ways...a) it will automatically pop a window up asking to update firmware....and b) nothing will happen and I simply turn off and on the DNS (with SD Card still in GPS slot). Then this pop up will come up. Say yes (or ok)
9) Firmware will be updated.
Yep that did update something mmore, as I never got that screen prior. Will see if anything is different. So far all seems the same with no additional settings
Hmmm okay, bug found. Put my mfd to audio, and not it wont come off audio, even pulled the radio fuse and no go, likely will have to d/c the battery to maybe reset this.
It is nice that the toggle switch ffor the mfd will change stations or tracks, give a point for that
Sandy can you make a list of which units and who is next on the list for the next batch? I was originally on the first batch list but then you changed it to the first come first served basis. If that is the case and my order hasn't come through since I am on the bottom of the heap now. I would like to withdraw my orders for both my units until the situation improves if that's alright with you.
I dont get the colourful screen. I get a white screen with small black text that says MPU Updating(or something to that effect). The it says MPU updated with an elapsed time of xxx. Pls Reboot. Then it reboots. I also dont get the calibration screen. It just boots to the UI.
I initially did it Sandy's way and all seemed to work fine. It did the MPU update then on the reboot it did the firmware flash. Could someone please list the correct revisions I should be seeing in the 'System Info' screen so we can know if it flash correctly or not.
Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
-MK1 Golf The re-spray/re-build
In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
A pattern seems to be forming...
Updated mine pretty painlessly. Interestingly, polski, my unit has been updated to BSP MS9.D.
Overall the unit seems much faster now, switched canbus on, and that side of it works... no slowdowns as such, yet, but time will tell.
FLAC playback has been significantly speeded up, files load pretty instantaneously now, the gaps between songs is less than 1s now, and skipping through tracks seems much quicker (and now probably limited by card speed). Still no metadata though (it just lists the file name).
Lots of minor issues still remain, though (particularly the not charging iPod on playback thing, which is just seriously frustrating, it makes the iPod playback feature basically pointless, SD tracks still mute on reverse, MFD is still 1 line (but I suspect that will be the last thing to get fixed)..... but at least it seems like the CANBUS slow down issue has been (possibly) fixed?
MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
According to a photo I took of the system info (when I first got the unit), my BSP shows as MS9.C - therefore polsk it doesn't appear your unit has updated correctly.
