View Poll Results: DNS unit group buy - discount options
Voters
123. You may not vote on this poll
  • raffle for free units according to number of orders
    56 45.53%
  • split the price of the free units between all orders
    67 54.47%
Page 138 of 181 FirstFirst ... 3888128136137138139140148 ... LastLast
Results 1,371 to 1,380 of 1806
Thread: Group Buy / EOI new generation DNS head units (RNS-510 alternative)
  1. #1371
    Hmmm just flashed the file, did a factory reset. System lag still remain (was trying to manually tune the radio) with the addition of the radio not wanting to turn off, or change its input....
    Ill do another factory reset, then pull the radio fuse then reflash to see if that fixes the issue
    Sent from my SGH-I337M using Tapatalk
  2. #1372
    Aspendale, VIC
    Great to see this back on track.
    Sandy can you confirm if the screen should be capacitive or resistive? This is the only hardware query I have.
    Apparently this was advertised as capacitive?
    2012 CS K04 GTI | GIAC | APR RSC 3" TBE | VWR Intake | KW V1 | OEM R Bi-xenons | OEM R Tails | Unibrace UB | S3 Intercooler | podi boost gauge | OSIR body kit | BBS CH
  3. #1373
    Quote Originally Posted by XQUIZT View Post
    It was at the start, now I don't see that posted anyplace unless I'm blind. That's a real let down, and explains the screen selection issues I've had.
  4. #1374
    Aspendale, VIC
    Quote Originally Posted by kwalsh24 View Post
    Let's see Sandys response because false advertising is a no no.
    If the unit has changed its specs it should be communicated to everyone & not have ppl guessing.
  5. #1375
    Yeah, as if I would of known, it would have likely made me stick to my ans unit. As my screen definitely isn't a capacitive, as I can use a plastic stylist to select my options lol, and have my notions automatically slected for me when I'm browsing as the center of the screen seems to like to do its own thing. Also didn't help that there's a resistive screen calibration at the flash reboot....
  6. #1376
    Aspendale, VIC
    Interestingly no-one has made a fuss about this.
    I'm in same mindset as you. Current RNS is resistive, capacitive screen was very tempting but if this is not the case, I won be dropping $700 for just software upgrade.
    I'll wait for the next generation.
  7. #1377
    KoSo I did the reflash, and noticed this error, Sandy, is this normal ?
  8. #1378
    First bug of new fflash, well actually iits an old one, SD playback, crash with this error & system freeze. Monsun.exe
    Bluetooth playback still poor, sysfem sometimes flips from input to radio then back.... still static in the background of SD playback.
  9. #1379
    Jun 2012
    Adelaide, South Australia
    So when I put the SD cars in and turn the unit on I should get colourful writing while it updates. Mine doesn't do this. Then it loads the second update part. Am I doing something wrong?
    Sent from my galaxy spaceship
    Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
    -MK1 Golf The re-spray/re-build
    In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
    A pattern seems to be forming...
  10. #1380
    says I have a bad sd after the GPS update. When I load the card into the sd slot just says bad sd card
