Great to see this back on track.
Sandy can you confirm if the screen should be capacitive or resistive? This is the only hardware query I have.
Apparently this was advertised as capacitive?
Hmmm just flashed the file, did a factory reset. System lag still remain (was trying to manually tune the radio) with the addition of the radio not wanting to turn off, or change its input....
Ill do another factory reset, then pull the radio fuse then reflash to see if that fixes the issue
Sent from my SGH-I337M using Tapatalk
2012 CS K04 GTI | GIAC | APR RSC 3" TBE | VWR Intake | KW V1 | OEM R Bi-xenons | OEM R Tails | Unibrace UB | S3 Intercooler | podi boost gauge | OSIR body kit | BBS CH
Yeah, as if I would of known, it would have likely made me stick to my ans unit. As my screen definitely isn't a capacitive, as I can use a plastic stylist to select my options lol, and have my notions automatically slected for me when I'm browsing as the center of the screen seems to like to do its own thing. Also didn't help that there's a resistive screen calibration at the flash reboot....
KoSo I did the reflash, and noticed this error, Sandy, is this normal ?
First bug of new fflash, well actually iits an old one, SD playback, crash with this error & system freeze. Monsun.exe
Bluetooth playback still poor, sysfem sometimes flips from input to radio then back.... still static in the background of SD playback.
So when I put the SD cars in and turn the unit on I should get colourful writing while it updates. Mine doesn't do this. Then it loads the second update part. Am I doing something wrong?
Sent from my galaxy spaceship
Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
-MK1 Golf The re-spray/re-build
In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
A pattern seems to be forming...
says I have a bad sd after the GPS update. When I load the card into the sd slot just says bad sd card
