View Poll Results: DNS unit group buy - discount options
Voters
123. You may not vote on this poll
  • raffle for free units according to number of orders
    56 45.53%
  • split the price of the free units between all orders
    67 54.47%
Page 134 of 181 FirstFirst ... 3484124132133134135136144 ... LastLast
Results 1,331 to 1,340 of 1806
Thread: Group Buy / EOI new generation DNS head units (RNS-510 alternative)
  1. #1331
    Quote Originally Posted by kwalsh24 View Post
    Yeah, I'm going to test with the canbus off, see what happens, as ever since my initial slow down its like the unit just self destructs after every factory reset, since my iinitial slow down I've had to reset it 3 times. Also my door que would tell me when a door was open, but then not go off when the door was closed.
    Also is anyone else finding that the screen sometimes has a mind of its own? Ill be scrolling thru the menu of my SD folders, touching the outside edge of the screen and suddenly the screen will select something in tthe middle of the screen. Its rather annoying, this would be a hardware issue with the non capacitive screen. Its like having a old school GPS system in my dash now.
    Sent from my SGH-I337M using Tapatalk
    Yea, had it happen again just then.
    I've turned the CANBUS module to empty for the time being, seems to be working fine now. I lose reverse camera tho, but at least it's stable haha.
    I've seen the same thing in the folder menu. I think it's just a bit sensitive, that's all.
    The other thing id like to see is when you go up a folder it puts you at the top, but I'd rather it put you where you were originally (say you opened a folder halfway down, when you go out it puts you at the top, but it should put you halfway down again).
  2. #1332
    Jan 2013
    Just wondering, is there anything specific that you're doing before the CANBUS issue arises? Maybe something in particular that triggers it or is it a completely random occurrence?
  3. #1333
    Quote Originally Posted by moda View Post
    Ill add to the SD playback, if you turn the car off, and the SD was in shuffle, turn the car back on and it remains in shuffle mode lol, instead of it going back to defaults.
    I also think I've lost sub out volume gain since the resets, will have to double check that my amp is turning on, sounds like it is but in the eq nothing changes when I adjust the sub gain
  4. #1334
    Quote Originally Posted by cpkk View Post
    Nope, seems to be fairly random. My guess is it's on startup, almost like it tries to grab the canbus data stream, for some reason can't grab it and just gives up which causes things to be slow.
    Can't decide if the canbus should be 'Off' or on 'empty'.... what have you set it on kwalsh?
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
  5. #1335
    I have mine set to off, so far things seem to be okay, minus my sub issue, don't recall the empty being an option haha. My bad. I just turn things to off that I know I don't have installed
  6. #1336
    Aug 2011
    Lake Macquarie
    Mine unit caught the lag bug tonight.
    As long as I can listen to the radio (when it lets me select a channel) I will be happy until they come up with what ever to fix it.
    I think!!!
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  7. #1337
    Jun 2012
    Adelaide, South Australia
    So, finally got mine installed today and went for a couple short drives. used the nav once, which caught on very quickly, even though i mounted the GPS antenna under the mk5 trim on the dash, and all went well, the GF played with the settings as i drove, so ended up with it just the way i wanted, and im happy with it, the rest of the unit, so far, only used FM radio + cd, and made 2 calls with the BT, and all went well, no issues at all, had it parked front to the sun during sunset, so the dash got pretty warm, and no issues with that either, for me, all seems to be going great
    Hope i don't get the lag bug, as i like how responsive it is!!
    Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
    -MK1 Golf The re-spray/re-build
    In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
    A pattern seems to be forming...
  8. #1338
    Jan 2013
    Hope it stays that way for you polski.
    I've noticed when playing music via SD that it takes a very long time to skip forward within a track. Do any of you experience that? My MP3 files are around 150mb...haven't tested with smaller ones. However didn't expect this to be an issue given the unit's specs and they work fine with any old smartphone.
    Sent from my GT-I9305 using Tapatalk
  9. #1339
    Jun 2012
    Haha. Funny about that. Driving to work this morning I notices it was very laggy. Did I a restore to default. And everything seems to be working fine again.
    150mb for an mp3? Why so big.
    Sent from my galaxy spaceship
  10. #1340
    Jan 2012
    Epping, NSW
    Think about it..need to skip forward, large file size.. is probably a podcast or gapless mp3 for a full album.
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
