Right. Reverse camera installed. Went smother than expected, didn't have to pull half the interior out, was able to snake the cable around the trim piece.
Wiring was as followed, for the license plate type camera:
Unit Side:
Yellow RCA -> Yellow RCA
BBattery -> Red wire on Yellow RCA cable
No other wires used.
Camera Side:
Red 3.5mm -> Red wire -> Red wire on Yellow RCA
Another bug found as well:
On iPod playback, using 30pin->Lightning cable, my iPhone doesn't charge. When playing back audio using another source (BT/SD/Radio), iPhone is charged as normal. For some reason it stops charging when you play audio through it. This is using both the 30pin->Lightning adapter and the 0.2m cable. Not sure why. Pretty ****ing annoying actually, considering i've got a big road trip coming up and a charged device is essential.
Edit: This bug is also present with an iPod connected straight to the 30pin connection. Sigh.
Ah sorry about that, I forgot that you have to set permissions for editing. I've set it for everyone to edit now.
