Maybe I'll just get each separate. Hmmmmmmm.
Also, anyone looking for the antenna adapter, just found one half the price of the one I bought.
http://pages.ebay.com/motors/link/?n...d=300868095480
Sent from my SAMSUNG-SM-N900A using Tapatalk
Something like THIS might fit there if you only needed the Aux port
for those of you wanting a more clean install for your USB / auxiliary. take a look at this. I'm thinking on getting this myself for my car... I'm guessing it will work, the plug for the USB looks the same, not 100% on the auxiliary harness as I'm not at my radio, but if its to use stock oligarchy this Otta work
eBay item # 151161329968
USB AUX Cable Wire AUX USB Switch FOR RCD510 RCD310 VW Touran Tiguan Polo | eBay
Besides the missing cables (which have some awesome OEM solutions as per above) are people still finding "hardware" problems? Again let me know your firmware as it may have shipped with an old one.
has anyone else had trouble with the camera? when I put it in reverse I get scrambled screen but if the car is turned off and I just turn the key once and then I put it in reverse the camera works fine why is this?
Could it possibly be a bad earth somewhere? Its pretty common to get interference/whine/bad signal in an audio feed while the engine is running from a bad earth so maybe you are getting something similar on the video feed?
Has anyone heard if the Aussie units made it out yesterday?
Sent from my GT-I9305 using Tapatalk
MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
Cool. Do you know what kind of shipping he was using? Wonder how long it will take to get to Sydney? Chances are I'll be out all week anyway so I'm going to have to go pick it up from their depot anyway...
Do you have the red wire (of the blue / red wire loom coming from the camera to front of car) connected to an always on 12v location? Do you have the blue wire of the same wiring loom connected to the "Battery +" wire coming out of the DNS and NOT the one that says reverse? Do you have that short black ground wire at the camera end connected to a bolt near the camera location in your trunk/hatch?
It seems to work when ignition is on and the car is not "on". This tells me there is a wiring issue and is not the DNS.
I'm not sure, but for some reason I'm thinking it was going to be via DHL? Can't remember. Either way, it should get to me tomorrow, so i'll let ya'll know.
