View Poll Results: DNS unit group buy - discount options
Voters
123. You may not vote on this poll
  • raffle for free units according to number of orders
    56 45.53%
  • split the price of the free units between all orders
    67 54.47%
Page 103 of 181 FirstFirst ... 35393101102103104105113153 ... LastLast
Results 1,021 to 1,030 of 1806
Thread: Group Buy / EOI new generation DNS head units (RNS-510 alternative)
  1. #1021
    Jun 2011
    Quote Originally Posted by raymondtrudeau View Post
    I got mine installed and where can I start with the problems?
    first the sd card will only read when you pull it out then put it back in.then it wont read my mp3's it may read the odd one then you cannot select the next song if you choose the song on the dns screen nothing happens.. just crashes..then if you select fm radio no sound comes from the radio..you have to turn off your car for 3 seconds then start up your car then you will get the radio to work...
    next the rear camera does not work...if the car is started and I put it in reverse it will switch over to camera mode but the screen goes all scrambled...but if I just have the car in accessory mode(just turn the key once no engine running) it will show the camera working..
    next the bluetooth I cannot get it to sinc with my car..i try to sink it with the steering wheel and it says syncing then finds my phone and says synced vw...I think it is syncing my phone to the car but not the dns810..
    very frusterating I want to send it back and exchange it for the ans810 I least that works...I think..
    sandy how can I send it back?
    You definitely have a faulty unit. I have PM'd you.
    As for the missing cables, I am really confused about that too. My sample unit came with all the accessory cables and I have no idea why they would not include aux and USB now. I'm not sure if I can find out before I leave - if not I will chase it up as soon as I return.
    You wouldn't have to worry about the update thing though, all updates are done through the GPS SD slot.
  2. #1022
    Jun 2011
    Quote Originally Posted by xxcynicxx View Post
    - I've had a couple issues with the Radio not pumping out any sound. The HU itself sends sound to the speakers, and I always get sound from the SD card, so I'm hoping it's just because I'm waiting on that FAKRA adapter.....we shall see.
    - When RDS is on, the unit kinda freaks out and constantly seeks for a new station. If I hit seek in either direction, it will stop for awhile and let me hit one of my presets, but that only lasts a few minutes before it starts seeking again.
    When you say radio not pumping out sound, is it when you leave the ignition on a while until after the unit starts booting / has booted, and then turn on the engine? I find the radio can lose sound if it is on and you then start the engine.
    With regards to RDS, did you change the region to USA? The setting is under menu -> radio. The seek thing also may have something to do with the RDS AF function for seeking alternative frequencies for the same RDS station when it thinks signal is weak. I find this to be more of an annoyance most times, I'll suggest they add an option to turn this off.
  3. #1023
    How do you pair a phone it won't work
  4. #1024
    Jul 2013
    Virginia, USA
    I'll check the radio sound thing later tonight. For RDS, yeah I turned the region to USA. Just going to leave it off for now.
    How can I disable the feature where sound is disabled while backing up? Can't find that in the menus.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  5. #1025
    Jan 2013
    I was getting excited, but now feeling a bit nervous...
    Re. AUX - is it possible to connect the factory AUX to the DNS unit? My car didn't come with a factory AUX input jack, but I'm looking at buying one of these: AUX IN Audio IN Switch Plug Cable FOR VW Volkswagen Golf 5KD 035 724 5KD035724A | eBay
  6. #1026
    Jun 2011
    Quote Originally Posted by chillybone View Post
    When in Bluetooth menu just connect to it on your phone and pair it like any normal Bluetooth device. I might able to help if you tell me what you're doing and how it's not working.
    It's in a hidden menu, you have to go to aux-in menu, then press and hold the middle of the far left of the screen.
  7. #1027
    hmm maybe I better just install this unit to make sure its nit faulty & not reassemble my dash so I can get the missing cables installed
  8. #1028
    Jan 2013
    A question re. SD cards - what's the minimum required size for the GPS SD?
    Also is FAT32 format the only the requirement for the SD card? I've read there are ways to format a 64/128GB SDXC card into FAT32 using third party utilities.
    Thanks.
  9. #1029
    Jul 2013
    Virginia, USA
    I used most of a 4gb card for the GPS software plus maps. I don't have a sdxc card to test.
  10. #1030
    Dec 2012
    I have a 64GB SDXC card in my phone so I can give it a go whemy unit gets here. I'll have to research the utility to do it though unless someone here knows it?
    Sent from my GT-I9305 using Tapatalk
