Picked mine up from the post office today and got it installed a few hours ago.
I havent had a chance to thoroughly test yet but it seems to be going good like modas (this is without a sd card, hopefully I can test that next week when mine arrives - ebay)
I've noticed a couple bugs similar to others that have been posted but the first thing (and I'm surprised no one has picked up on this) is that its not a capacitive touch screen, still resistive. Unless I read that wrong initially, I was expecting it to work like a modern smart phone instead of my old rcd unit. It seems more sensitive and better than my stock unit, was just thinking it would be different is all.
Overall the unit seems very quick, definitely faster than my stock one. I thought the resolution would be a bit iffy but looks great. Radio quality is good but I’ve only tested on Nova and Edge which is notoriously bad. It did drop out a couple times on Edge (no issues with Nova) and then it showed a weird scramble of letters and symbolsbut fine after I went from Nova back to Edge.
I opted to get the digital tv add on and so far using a standard pair of bunny ears I've only got the sh*tty channels but I've ordered a slightly better antenna (the unit comes with a double antenna output) which I'm hoping will help pick up normal Aussie digital channels (7,9 10 etc), wont know for a few weeks.
Ok so the issues I’ll try to add to the google doc that haven’t already been mentioned, which are very basic compared to some of the others I’ve noticed but..
*On radio mode when I press ‘extras’ it scans through the frequencies
*I forget what its called but theres an option for internet browsing, when you go to enter a different URL a keyboard pops up, but its way too small to use. I don’t know how to get internet working on this yet but it seems like a cool feature, any thoughts?
*I’ve got a two door golf not a four door, there was no option for a two door when selecting my car type (for the door open monitor)
*the GPS doesn’t like roundabouts. Mine is a little slow on 90 degree corners but roundabouts seem to confuse it a bit. I can try to upload a video if you guys wanna see what I mean. I’ve never had a GPS unit before so I don’t know if they all act that way, but I wouldn’t have thought so.
Oh I have a question, does it matter which way I face the GPS receiver? It’s currently sitting upside down with the cable 90 degrees from the unit so its sideways when you think about it, will that affect how it picks up its signal?
Also I have a sub installed, done in a shop and I was wanting to hook it up the proper way to the unit. This is what I found when I removed my current unitLooking at the cables that came with it I noticed that there is only one cable for the sub but looks like two cables coming from my amp. I’m not sure what the existing converter does but its wired directly into my canbus cables. I have a separate sub gain control knob but guessing that for optimal use I can just unplug it and control everything through the head unit?
It was a hot day today and the unit was working fine. Our winters do get pretty cold so wondering if I’ll encounter problems down the track but in the heat its not getting those weird scrambles others have noticed. Software version is![]()
