Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Group Buy Autopolar FIS+ Advanced
    Just in case you haven't visited the VW Car Audio and Electronics area recently I'm posting here also. I've arranged a group buy for Autopolar FIS+ Advanced units. The guys at Autopolar have said they'll foot the freight bill for a group buy so all you pay is the cost of the unit EUR249 / AUD$300 pick-up/drop-off in Adelaide or add $10 shipped anywhere else in Australia.
    PM me if you're interested. I'll look to get numbers finalised by the weekend.
    What parameters can be displayed with Polar FIS+ Advanced ?
    Answer: A whole bunch of neat stuff including
    - Real speed (read from ECU)
    - Oil temperature (°C / °F)
    - Coolant temperature (°C / °F)
    - Outdoor temperature (°C / °F)
    - Admision temperature (°C / °F)
    - Turbo pressure
    - RPM motor
    - Voltage of the battery.
    - Fuel remaining (Litres / Gallons)
    - Atmospheric pressure
    - Pressure fuel pump
    - Motor load.
    - Ambient Temperature (engine ECU)
    - Coolant temperature engine output.
    - Coolant temperature leaving the radiator.
    - Mass air flow
    - Admision pressure
    - Sensor 1 throttle pedal
    - Sensor 2 throttle pedal
    - Sensor 1 throttle valve
    - Sensor 2 throttle valve
    - Horse power used (CV)
    - Oil level
    - Minimum oil level
    - Brake master cylinder pressure
    - Pressure in the fuel rail
    - Torque used NM
    - Injection timming
    - Injection quantity
    - Injection angle
    - Injection start
    - TV Free function
    VERY IMPORTANT INFORMATION
    Not all parameters are supported in all engine ECU, to know that data can be displayed, see the list of supported ECU:
    http://www.auto-polar.com/downloads/Supported_ECUs.xls
    Complete list of models supported are as follows:
    - Volkswagen Golf5
    - Volkswagen Golf6
    - Volkswagen Jetta
    - Volkswagen Caddy
    - Volkswagen Tiguan
    - Volkswagen Touran
    - Volkswagen EOS
    - Volkswagen Passat
    - Volkswagen Scirocco
    - Volkswagen Sharan
    - Volkswagen Touran
    - Volkswagen Tiguan
    - Skoda Octavia (1Z) -Pre y Restiling
    - Skoda Superb II
    - Skoda Fabia (new)
    - Skoda Roomster
    - Seat Toledo 2012 (new)
    - Seat Alhambra
    - Seat Leon
    - Seat Altea
    Sorry to Polo owners due to hardware simplification it appears there's no connector for your Autopolar to plug into at this stage.
    There's also a bunch of other features including:
    - Mirror dipping on selection of reverse
    - Adjust number of comfort flashes
    - Modification of the sensitivity of the rain sensor.
    - Modification of the sensitivity of the light sensor.
    - Enable / Disable American DLR.
    - Enabling / Disabling daytime running lights.
    - Enabling / Disabling cornering fog lights.
    - Enabling / Disabling second rear fog light (where bulb exists).
    - Enable / disable automatic closing from 15 km / h.
    - Enable / disable rain closing.
    - Enabling / Disabling one touch closing windows.
    - Enable / Disable hazard warning in case of sharp braking.
    NOTE: These functions, Polar Advanced FIS performs are via coding of the ECU with the requested function, so if this function is not supported by your vehicle ECU, then it cannot be activated.
    For more details you can visit the auto-polar site: polar-fis-advanced
    Please note as of 2 November these units now support white MFD as well as the older red MFD. Different firmware versions are downloaded by the USB cable supplied with the unit.
    Apr 2008
    I'm interested
    Put me down for one!!!!
    Aug 2011
    Do you mean the Half Height Red MFD??
    Oct 2011
    Atwell, WA
    looks like i'll have one for sale soon... not even used... won't suit my polo gti
    2012 Volkswagen Polo GTI (Shadow Blue) | Current Upgrades - APR Stage 2 Tune | GFB DV+ | HP Cold Air Intake | OKADA Plasma Direct Coil Packs | HP Exhaust | HP DQ200 Tune | Whiteline Rear Sway Bar | Uprated Engine Mounts Planned Upgrades - | Coil Overs | HP Intercooler |
    Quote Originally Posted by RandomX View Post
    Hope the Autopolar guys can sort out something for the Polo's soon as I think there a couple of other VAG models that may have a similar set-up.
    Quote Originally Posted by lankfert View Post
    I think you need the full height red MFD - will need to check and confirm.
    I too have the half height mfd .. will it still work?
    Quote Originally Posted by nunoluis82 View Post
    Short answer is no.
    You need the full height MFD (either white or red) for the autopolar unit to display all the data.
    So only full height displays will work with this device.
    **** lol... I can't use it dammmit
