SOLD
This will give you a super capable factory-look GPS.The Zenec is especially good value if you want Bluetooth, RVC or are installing in a pre 2007.5
Suits Golf & Jetta MkV, MkVI, Caddy, Tiguan, Scirocco, Polo V, Passat, Amarok, T5 Transporter
Features:
- Factory fit, matches the OE fascia panel
- GPS Navigation with E-Go Australian maps
- Integrated Parrot Bluetooth system, with external mic
- DVD & Mp3 functions
- SD Card slot
- Factory Dual-fakra antenna input
- Steering wheel controls, MFD+ integration, Climatronic and parking sensor display [if your car has these]
- Red or white button illumination
Advantages over a RNS-510:
- Integrated Bluetooth, no need for a $150+ Bluetooth module
- No need to replace the Canbus in CAN 1.6 cars (~$150+coding for 2004-2007.5)
- Rear-view camera connector will accept inexpensive non-factory RVCs
- Line-outs for subwoofer and aftermarket amps, you won’t need a hi-pass filter
- Dedicated rear-seat screen and audio outputs
Zenec NC2011D Information Brochure
Imgur Photo Gallery
All cables excl. canbus adapter are included – including a GPS antenna. Unit can plug into the factory GPS antenna if you have one installed already.
Still available.
CAN interface/Quadlock is included. Ready to install.
