Results 1 to 10 of 16
Thread: P3cars vw tiguan vent intergrated digital interface
Threaded View
    Oct 2010
    P3CARS VW TIGUAN VENT INTEGRATED DIGITAL INTERFACE RRP$489 Selling $300ono As New Fascia not included!!
    Connect with your car in an entirely new way. Why settle for just a boost gauge? Sporting features available in products 3x the price, this is a swiss army knife of performance data, with design and integration that won't spoil the clean lines of your interior.
    Specifically designed to support the VW Tiguan platform. Reads boost and all data directly from the diagnostics port for fast plug and play install.
    Plug and Play install
    Quick plug and play install with zero cutting required. All power, ground, and data points come directly from the diagnostics port connector.
    Boost/Vacuum Display
    High resolution boost/vacuum via diag port for FAST install. Optionally read boost via boost tap (not included).
    Multiple Gauge Displays
    Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more!
    Peak Recall & Run Record
    Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background.
    Universal Aux Inputs
    Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values.
    On the Fly Configuration Menu
    Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more!
    MY10 Tiguan 125TSI /APR Stage 2
