Hey Ben, the offset is slightly different to the Rocco but if they are ok then i'll be keen on these
SOLD
VMR 810 Flow Formed Wheels
19" x 8.5
Offset 45
5x112 Stud Pattern, suit VAG Golf R etc
Grey
Perfect condition although there is 1 tiny chip (see pic)
Only been on the car 4 months
Local Brisbane pickup only
$1100
BMW Z4 (2019)
Audi TT quattro (2015), s-line in Nano Grey - sold
41 I believe
BMW Z4 (2019)
Stock Scirocco wheels are 18x8 ET41 and the option wheel is 19x8 ET41.
These rims will poke 2.5mm further, however will also be 10mm closer to the strut/suspension than the stock wheel.
It would probably work OK, however if you wanted a more "flush" fit on the Roc you'd need to look at something closer to a +35 offset.
Thanks for the info. The Oz Scirocco only came with the 19" wheels so these should be OK then
The width/offset is the same so the comparison is still valid. There's a number of online wheel calculators that will run a comparison between difference sizes/fitments.
You'd likely run the same tyres on 19x8 as 19x8.5. Straight swap over![]()
Thanks Tigger! 😃
Sorry guys, i havent been online this weekend. They're sold to the first person that PM'd me PENDING payment of course.
