I recently purchased this Podi boost gauge kit for my Mk6 GTI but have now decided to get a P3 gauge instead. This gauge and all wiring etc is all brand new (only removed from plastic packaging to look at and test fit in the car). The only part of this boost gauge kit that I have used is the boost line and the boost tap – as I started to install these parts before removing them off the car. I have also put some Silastick sealant around the brass nipple that comes off the boost tap to help avoid any potential leaks. Everything is as new (not damaged or scratched etc) and ready to install. I will also provide the receipt/invoice in case the buyer ever needs it.
Please note (and this has been reported by other people who have this gauge) that the alloy boost tap needs some light modification/filing in order for the PCV tube to click onto it properly. I am happy to do this for the buyer or I can leave it alone and you can do it yourself.
If you click on this link, it’s the 3rd gauge package down the page: Podi.ca | Gauge solutions for Audi and VW
Includes:
- Podi stepper boost gauge (to match Mk6 GTi) in PSI
- Podi steering column moulded mount trim piece
- Podi electronic boost pressure sensor/sender
- Podi alloy boost tap and silicone/rubber boost line to run from inlet manifold into the dash area
- Podi wiring and fuses needed to hook it up
- Little air filters to be used with the boost line to stop condensation
- Remote control
- Choice or matte black bezel or satin chrome (comes with both) for the gauge
More info:
- Podi steering column gauge pod (Patent Pending)
- 100% electronic stepper motor based boost gauge (-30inHg/30psi)
- Multiple LEDs used for backlighting (16 for dial, 4 for needle)
- Red needle with selectable red/white color backlighting
- User adjustable brightness
- User programmable overboost warning alarm
- Peak value recall
- Anti-glare coated glass lens
This cost me $340 AUD ($285 USD incl boost tap and international delivery) delivered from Podi in Canada.
Selling for $300 including delivery Australia wide.
