Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: FS: heaps of mk1 + mk3 parts
    May 2012
    Tullamarine
    ive got a bunch of mk1 gld parts that was on my golf that i stripped and also got a few mk3 parts from the engine that i no longer need.
    my old man was going to turf them so i thought ill take a few pictures of what i got and what doesn't sell ill take to the tip.
    MK3 parts
    - throttle body inlet manifold = $50
    - air conditioning compressor = $40
    - distributor with leads = $50
    - exhaust manifold= $15
    - power steering = $40
    - automatic clutch bolt plate = = $10
    - engine bay wiring loom = $20
    - power steering and main crank pulleys = $5 each
    MK1 parts
    - mk1 original headlights = $45
    - ml1 hex head clutch cable = $25
    - bar + tow ball = $20
    - GLD exhaust (cut in half) = $20
    - 1.8l flywheel = $45
    - GLD starter motor = $40
    - discs = $20 both
    - calipers = $20 both
    - oil sump = $30
    - rocker cover = $10 each both sold
    - alternators (petrol,diesel) = $25 each
    - 1.8l, 8v cam shaft rod = $25
    - cam pulley = $5
    - 1.8l exhaust manifold = $15
    - engine mounts = $5
    - rear mount for gearbox = $20
    - distributor = $10 sold
    - engine gaskets = $10
    - GLD timing belt cover = $15
    - breather hose = $15 each
    - GLD fuel filter housing = $25
    - GLD fly wheel = $45
    - 1.5l diesel engine (is in half) = $70 both pats
    - GLD 4 speed gearbox = $150
    ill need these gone asap my old man is cleaning the yard and what doesn't sell will go to the tip!
    prefer local pick up, if item is a reasonable weight ill post within Australia which will be on buys expense! if its a heavy item you'll need to organize a courier to pick up and drop off which will also be under buyers expense! pm me what your regarding and we can go from there.
    thanks
    steve
    MK1, 1976 golfLS, 4 door (SOLD! Will be missed)
    MK1, 1980 golfGLD, 4 door (1.8l, 8v, 5 speed)
    May 2012
    Tullamarine
    Bump!
    I don't want to throw any parts out need majority of them gone!
    Oakleigh VIC
    I'll grab that dizzy please.
    PM sent
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    May 2012
    Tullamarine
    bumpppp
    May 2012
    Tullamarine
    Need to go before the end of the moth!
    Make me an offer
    May 2012
    Tullamarine
    Bump!!!
    May 2012
    Tullamarine
    Bump! Few reasonable parts for your mk1/mk3 golf that's not worth throwing out! Need them
    Gone ASAP
    May 2012
    Tullamarine
    Bumppp
    May 2012
    Tullamarine
    Bump need parts gone before I scrap them
    In!
    May 2012
    Tullamarine
    Also got for sale are
    Mk1 original headlights $30 for the pair
    Mk1 hex head clutch cable $20
