Ignore the 5x114.3 label - that's another set of adapters. The above description is correct.
Hi guys.
Gonna be moving on to another car so my new adapters are for sale. Specs are as follows:
Set of four
5x100 to 5x112
15mm all around
57.1mm centrebore, 57.1mm hub bore
All hardware included (flush bolts to fit adapter onto car, conical-seat nuts to fit wheels onto adapter)
These are perfect for fitting OEM 5x112 VW/Audi wheels onto your 5x100 VW/Audi. Will locate properly onto your hubs without play. If you are deciding to fit OEM wheels, you might need ball-seat nuts to secure the wheels properly, but this is just a small extra cost.
These are new and not fitted. Ordered originally from Stu.
$350 takes them.
Keen! Going to Nationals?
