hey
how hard is it to ft dynaudio to MIB2 in a scirocco and is it worth it?
cheers shane
Hello
For sale is from VW Tiguan 2 R line Radio Unit Harman rrp$3500 (VW PART No: 3G 035 045 C ) MIB2 Main Unit Discover Pro Navigation top of range with built in Hard drive, Navigation, BT , Voice , MOST Optical Fibre connection which is needed to retrofit or add Active info Display to Display Navigation map on dashboard and Radio display in same time or to upgrade to retrofit Dynaudio Digital amp . Will suit Tiguan 2 . Golf 7, Passat B8 and some other however please research your VW dealer or installer for compatibility with your car . Unit is from 6mth only Tiguan 2 r-line as new car . 100% fully tested working same as new , .Installation in Sydney an CP removal can be arranged at extra cost .
Price $900
hey
cheers shane
2016 Scirocco R - 2015 Polo GTi
Hi
Didn't install directly on sirocco . However all retrofits need skills and lots of spare times for rewiring to install , offcourse if you have all parts and original ready VW caballing for retrofit. If you thinking doing all yourself without original wiring than you will need weeks and lots of nerves to finish
Regards
I got the nerves just reading your reply
