Hey Guys,
I am selling my Custom Code Stage 1 ECU if there is interest.
RRP is $749
The ECU identifier is '06A906018CH', as can be seen in the example picture below.
It is a straight swap and go install on Mk4 Golf GTI's with the above ECU identifier.
If the identifier is different, you will need access to VAGCOM to sync the new ecu with the cars immobiliser. Takes no more than 5 mins.
This has been a fantastic tune that really transforms the car into what it should have been from factory. The local support provided by Gavin (h100vw) of Optimum Code (Australian rep for Custom Code) is of a very high standard. He has helped me out on a few occasions when he really didn't have to and has always provided friendly local support. Thanks Gav!
If you are interested please send me a PM and we can sort out arrangements.
Thanks
Thanks Gavin.
Further to this, the immo Gavin is referring to is the 3rd revision of IMMO. Vagcom website qoutes:
So cars upto 2001 should be fine.Immobilizer Generation 3
Many 2002 and newer Model Year vehicles sold in the North American Region (NAR) have Immobilizer 3 and there are other Rest of World (RoW) Vehicles with Immobilizer 3 as well.
If you have vagcom there is a easy way to identify what IMMO your car is currently running:
To identify an Immobilizer 2 Vehicle, use VCDS to Select the Instrument Cluster (or Address 25 - Immobilizer in Vehicles with a separate Immobilizer Control Module) and look in the Extra Field. You should see a 14 digit Immobilizer ID Number such as Immo-ID VWZ7Z0W0648696. There should NOT be a 17 digit VIN Number in the Extra FieldsTo identify Immo 3 vehicle, Use VCDS to Select the Instrument Cluster (or Address 25 - Immobilizer in Vehicles with a separate Immobilizer Control Module) and look in the Extra Field. You should see BOTH a 14 digit Immobilizer ID number and ALSO a 17 digit VIN number in the Extra fields like this: WVZKB58001H231169 VWZ7Z0W0648696.
Why for sale??
Alba European
Of course Duh!! lol
Alba European
I'm on the slippery stage 2 slope
Friday bump
