Results 1 to 2 of 2
Thread: Cheap 15" semi-slicks 195 and 205
    Oct 2010
    Melbourne, VIC
    I have 3 x 195/55R15 Yokohama Advan A048R and 3 x 205/50R15 Advan A048R semi slicks for $25 each or $130 for the lot.
    They have about 3mm of tread left except for one of the 195's which has more
    They will be fine for motokhana, hill climbs and track sessions, except that the 195's should not be used on drive axles in track sessions as they are old stock and will fail under the heavy, extended load (the belts in the sidewalls break down and wires start poking out the side but they don't leak so it's not a sudden catastrophic failure).
    I have run them on my Polo with the 205's on the front and the 195's on the rear on track sessions without issue.
    195/55R15
    205/55R15
    Please PM me if you are interested
    Resident grumpy old fart
    Oct 2010
    Melbourne, VIC
    pics added
