Results 1 to 2 of 2
Thread: Burger Motorsports JB1 Performance Tune - Audi, VW, Skoda, Porsche - Group 1-6
    Mar 2021
    Geelong, VIC
    Cool Burger Motorsports JB1 Performance Tune - Audi, VW, Skoda, Porsche - Group 1-6
    Burger Motorsports JB1 Performance Tune - VW Golf GTI, R, Tiguan, Polo, Audi A3, A4, S3, TT - Group 1-6 EA888 engines
    This piggyback computer provides an instant power increase, turning your car into a beast without the risk of voiding your warranty (need to make sure you remove it before you take it in for service though).
    Pulled from VW Golf R Mk 7, running Map 6. Also, comes with the optional USB cable so you can change the maps via laptop. In perfect condition, no broken clips!
    This is the revision 2 version which can easily be upgraded to JB4 via an add on pack from Burger Motorsports (or Aussie sellers like AutoInstruct).
    Please note: Burger Motorsports list different parts on their site for Group 1-6 of the EA888 engines, however, this is only for them to track what cars these are installed on, the JB1 tuner is actually the identical part, so will work on any of the Group 1-6 engines.
    $320 posted anywhere in Aus for VW Watercooled members (also listed here on eBay)
    See below for full list of compatible vehicles.
    Full product details as follows:
    Burger Motorsports JB1 Performance Tune (Rev 2)
    The JB1 is a true user adjustable plug and play solution for all MQB based models in the VW Audi Group range. Adjustment procedure, software download and further information can be read here. JB1 R/S3 specific user hangout with 100’s of testimonials in this thread.
    Power Gains
    2.0 Golf R (and similar) Power Gains at the Wheels
    Starting at 33kW (45bhp) and 61Nm (45ft-lb) on 95 RON with + 4.80psi boost over stock on the default MAP1 setting. Up to 67kW (90bhp) and 94Nm (70ft-lb) with bolt on modifications, higher octane and boost adjustment with the optional BMS Data Cable.
    2.0 Golf GTI (and similar) Power Gains at the Wheels
    Starting at 26kW (35bhp) and 61Nm (45ft-lb) with 95 RON with + 4.80psi boost over stock on the default MAP1 setting. Up to 67kW (90bhp) and 94Nm (70ft-lb) with bolt on modifications, higher octane and boost adjustment with the optional BMS Data Cable.
    1.8 Polo 6C GTI (and similar) Power Gains at the Wheels
    Starting at 15kW (30bhp) and 48Nm (35ft-lb) with 95 RON with + 4.0psi boost over stock on the default MAP1 setting. Higher numbers are possible with bolt on modifications, higher octane and boost adjustment with the optional BMS Data Cable.
    Optional: Genuine Burger Motorsports JB1 Data Cable
    This proprietary Data cable connects the JB control box to your laptop for use with Burger Motorsports datalogging, tuning, and map loading software. Cable may be left in engine bay and routed in the window or door when needed for a simple install. Alternatively it may also be routed behind the ECU in to the glove box for a clean install and on the fly access.
    Please do not attempt to use a standard RS232/USB cable with the JB as it will not work and may damage the processor. All JB software is posted on n54tech.com.
    Full list of compatible cars
    2.0L Applications
    Audi S3 8V 2.0T
    Audi A4 Quattro B8.5 (Selected Models – Click Here)
    Audi A3 2.0T
    Audi S1
    Audi TTS 8S
    Audi TT 8S
    VW MK7 Golf R
    VW MK7 Golf GTI
    VW MK7 Golf GTI PP / 40th Anniversary / Clubsport
    VW MK7.5 Golf GTI
    VW MK7.5 Golf R
    VW MK2 Tiguan 220hp/162kW
    B8 Passat 2.0T 280hp
    Skoda Superb 280
    Skoda Superb 2.0T
    Skoda Octavia RS
    1.8L / 2.0L 185kw Applications
    VW Polo 6R / 6C GTI with 141kW Engine
    Audi A3 8V 1.8T FSI Non-US
    Skoda Octavia 1.8T FSI
    Audi A1 1.8TFSI
    Audi B9 A4 2.0TFSI 252hp / 185kw
    Audi B9 A4 2.0T Allroad 252hp / 185kw
    Audi A5 2.0T TFSI 252hp / 185kw
    Audi A6 2.0T TFSI 252hp / 185kw
    Audi Q7 2.0T TFSI 252hp / 185kw
    Porsche Macan 2.0T 252hp / 185kw
    2021 VW Tiguan Allspace Highline 162TSI R-Line (His)
    2018 Ford Escape ST-Line (Hers)
    Mar 2021
    Geelong, VIC
    Bump
