Results 1 to 4 of 4
Thread: BBT Hybrid K04-023 + TIP
    Nov 2013
    Bathurst
    Selling my brand new BBT Hybrid K04 023 to suit 1.8t
    (google beachbuggy turbo k418 if you wanna research the unit)
    Turbo specs
    BBT Ported K04-0023 Turbine housing
    BBT K04 compressor housing
    TFSI turbine 44.5mm/50mm
    BBT designed 7+7 2283 compressor wheel with ETT
    BBT uprated thrust beating/collar
    BBT improved O-ring sealed backplated
    Step gapped rear seal
    BBT uprate 15Psi actuator
    Power :
    330+bhp. Suporting mods are required (mainly upgraded connecting rods). already proved to run over 365hp with the Badger5 high flow cast manifolds
    Also comes with a brand new forge 3" TIP and can supply manifold + oil lines for non s3 buyers. Easiest bolt on kit to upgrade power and keep everything looking stealth!
    $1300
    if if you would like more photos don't hesitate to message me.
    0488613 six two two
    Lucas.
    Nov 2013
    Bathurst
    BUMP
    Make an offer!
    Need it gone ASAP.
    Jun 2011
    Sell just the TIP?
    Nov 2013
    Bathurst
    Yes happy to seperate. $150
    Brand new never used 🙂
