Here's your chance to own a reasonably rare set of Autostrada Modenas, staggered in 8/9". A cult wheel, with an iconic chunky five spoke design.
These ones are particularly unique, the normal center piece which screws on has been removed and I had them milled down, with custom center caps cut. You won't find another set that look like this.
They are full 3 piece wheels, and have been fully restored. The face and barrels have been finished in a space grey powder coat, with brushed alloy spoke detailing, polished lips, and chrome plated bolts/nuts.
I had these running on my Mk3 Golf, using the pictured adapters. If wanted, the adapters can be had too for an extra $200. They result in perfect offset for a Mk3.
$1500AU landed
Specs:
Diameter: 17"
PCD: 5x114.3
CB: 67mm
ET 8": 39
ET 9": 39
Adapters:
PCD: 5x114.3 to 5x100
CB: 67mm to 59.1mm
Width: 15 and 17mm
Note: As pictured, one of the 8" barrels has had a minor crack repair from Brugar after hitting a pothole. The rim is still straight and true, and the repair is of very high quality. Minor curbing on the lip of the same rim, about 5cm
2016 Golf Alltrack
Previous:
Mk3 1.8t
