Results 1 to 9 of 9
Thread: Adam's rear rotors 286mm double slot (used with 11.7mm thickness left)
    Jan 2011
    Brisbane - QLD
    Some things to clear on my part out exercise:
    A pair of rear Adam's rotor double slot, used with 11.7mm thickness left. Min wear limit is 10mm.
    Size is 286mm and will suit Mk5 GTI and Mk6 GTI (with TRW rear brakes, built prior to September 2010), and any VAG cars with PR code 1KV,1KY,1KZ for the rear brakes, e.g. Tiguan.
    Wear limit technical info:
    Volkswagen Workshop Manuals > Golf Mk5 > Brake systems > Technical data > Technical data for brakes > Rear brakes (disc brakes) > Rear brakes CII*38
    Pick up from QLD 4152 or post interstate at buy'er's cost.
    SOLD
    Photos taken this evening.
    MINI Cooper S Clubman - FWD
    Jan 2011
    Brisbane - QLD
    Price drop
    Jan 2011
    Brisbane - QLD
    bumpbump
    Jan 2011
    Brisbane - QLD
    $88 for the whole lot you see below:
    suitable for any golf 5 & 6 (non R32/R). small upgrade to golf mk6 gti's post november 2010 build that come with smaller rear brakes 272cm instead of 286cm.
    the above rear calipers came off a vw golf mk5 gti and i used them in my mk6 gti (to replace the smaller mk6 gti 272cm rear brake discs and very limited rear pads options).
    pick up preferred.
    Jun 2014
    Adelaide, South Australia
    Will these fit a mk5 non.gti? If so pm me.
    May 2009
    Canberra
    Would this fit 07 Passat @nat225
    Jan 2011
    Brisbane - QLD
    Quote Originally Posted by ajvx01 View Post
    as far as i know, these can fit golf mk5 and 6 cars as they share similar rear axle uprights.
    Quote Originally Posted by revhead1016 View Post
    not sure, never had a passat but assuming 07 passat comes with rear electronic brakes (like in passat r36), then no.
    Jan 2011
    Brisbane - QLD
    to the top
    Sent from my GT-I9506 using Tapatalk
    Jan 2011
    Brisbane - QLD
    BUMP, $80 for the whole lot minus brake pads and the 4 small caliper pin bolts.
