Price drop
Some things to clear on my part out exercise:
A pair of rear Adam's rotor double slot, used with 11.7mm thickness left. Min wear limit is 10mm.
Size is 286mm and will suit Mk5 GTI and Mk6 GTI (with TRW rear brakes, built prior to September 2010), and any VAG cars with PR code 1KV,1KY,1KZ for the rear brakes, e.g. Tiguan.
Wear limit technical info:
Volkswagen Workshop Manuals > Golf Mk5 > Brake systems > Technical data > Technical data for brakes > Rear brakes (disc brakes) > Rear brakes CII*38
Pick up from QLD 4152 or post interstate at buy'er's cost.
SOLD
Photos taken this evening.
MINI Cooper S Clubman - FWD
Price drop
bumpbump
$88 for the whole lot you see below:
suitable for any golf 5 & 6 (non R32/R). small upgrade to golf mk6 gti's post november 2010 build that come with smaller rear brakes 272cm instead of 286cm.
the above rear calipers came off a vw golf mk5 gti and i used them in my mk6 gti (to replace the smaller mk6 gti 272cm rear brake discs and very limited rear pads options).
pick up preferred.
Will these fit a mk5 non.gti? If so pm me.
Would this fit 07 Passat @nat225
to the top
Sent from my GT-I9506 using Tapatalk
BUMP, $80 for the whole lot minus brake pads and the 4 small caliper pin bolts.
