The liquid gauge is a great bit of kit. It can display pretty much any variable such as boost, AFR, temperatures etc. Also can help diagnose faults and clear fault codes. More information can be found here: Race Diagnostics Ltd - liquidA3/S3 opions
$270 shipped
I'm selling because I have other gauges now so no longer need it. It's designed for the facelift (later) 8L A3 or S3 models. They usually retail for £225 so grab a bargain.
Features
- Main Menu
Gauge Display
Graph Display
Speed timing
Faults and adaptations
Multigauge (Coolant, Manifold air temp, Exhaust temp and Oil temp)
Setup
- Sub Menus
- Gauge Display
Engine power
Torque
Boost pressure
Cmd pressure
Mass Air Flow
Air Fuel Ratio
Air intake temp
Exhaust temp
Coolant temp
N75 position
Oil temp
- Graph data
Engine power
Torque
Boost pressure
Cmd pressure
Mass Air Flow
Air Fuel Ratio
Air intake temp
Exhaust temp
Coolant temp
N75 position
Missfire
Dyno plot
Timing Correction plot
- Speed timing
0-60mph acceleration timing
0-100mph acceleration timing
- Faults and Adaptations
Display and Erase Fault Codes
Big turbo setting for up to 500hp engines
English, French, Finnish and German language versions
Imperial or Metric units
'02 S3 & '09 R36 Wagon
Sold !
