Results 1 to 3 of 3
Thread: 9w7 Bluetooth module suits VW and Skoda
    Part number 7P6 035 730 M.
    SW 4217 HW16
    $200 pickup or $210 inc shipping Aus wide.
    Comes with foam mounting surround, OEM microphone and cable.
    DOES NOT have a wiring harness, however these can be bought on Ebay for under $50.
    Ideally this would suit someone who has an older 9w2 or 9w7 without A2DP bluetooth streaming looking to upgrade, as I've already used the harness. It will be a straight plug n play. Otherwise needs the harness.
    I can install and code for a buyer in Sydney for free.
    Key features:
    Voice Command;
    A2DP/Bluetooth Audio Stream;
    White MFA+ / DIS (Driver Information System in instrument cluster);
    Multicolor MFA Premium / DIS;
    Compatible with all mobile phones;
    Shows title of A2DP - Bluetooth Audio Stream.
    Can be operate by:
    Multifunction Steering Wheel;
    RNS315 / RNS510 / RNS310 and similar;
    RCD 510 (Voice command will not work / Artist name and song title will not appear on the screen / Buttons "play" or "skip" will not be active);
    SKODA Columbus;
    SKODA Bolero (Voice command will not work / Artist name and song title will not appear on the screen / Buttons "play" or "skip" will not be active);
    Seat Media System.
    Can be installed in cars:
    without MFA / DIS / FIS;
    with red half FIS (don't show no information on instrument cluster display but only on Radio/navigation display) |unless you will get FIS LINK Can Box Converter|;
    with red FIS / MFA / DIS (than can be ONLY operate the module by a touch screen RNS510 / RCD510 - don't show no information on instrument cluster display) |unless you will get FIS LINK Can Box Converter|;
    with White MFA;
    without multifunction steering wheel.
    VAS / VCDS Coding after installation required.
    Jul 2013
    What is the benefit over a Kufatec Fiscon kit?
    Not sure as I don't know the Fiscon's capabilities.
    Does it do AVCHP 1.3 ie artist/track info in MFD and on head unit, and can you skip forward/back using the controls on the steering wheel?
    Also where is the mic located for your Kufatec? OEM mic goes in the headliner just aft of the map lights.
    Could possibly have better voice quality if it has a button mic located on the A-pillar.
    However this unit isn't compatible with your 8 button MFSW (which is why I have it on hand).
