Results 11 to 20 of 23
Thread: 1996 Black VR6 part out
    Mar 2014
    Coffs Harbour
    Clamshell around steering column is it adjustable if so I'll take it
    Mar 2014
    Coffs Harbour
    Also plastics on top of engine if got I'll take
    Jan 2009
    Melb, VIC
    Dylan8 - no leather or fogs.
    AAlocksmith - i didnt know these even had one! Where is it located?
    Jan 2009
    Melb, VIC
    Vr6hatchbacker - ill get back to you on the plastics. I got the clamshell though one mounting point has cracked so it moves around a little (common problem)
    Mar 2014
    Coffs Harbour
    I'll take it how much and postage to coffs harbour
    Sep 2006
    Parkinson / Brisbane
    Quote Originally Posted by AALocksmiths View Post
    Hi Phil,
    How much would you be after for the immobiliser box?
    mate, you'll need the ecu also for the box to talk to it; they're a linked item, key chip also too but maybe you have ways around that.
    Quote Originally Posted by pisana View Post
    the box is located up above the clutch pedal behind the dash.... little black box secured with two screws
    Quote Originally Posted by KI11Z View Post
    I'm only after it as I like to have spares of stuff like this. I can write a new key into it so I don't need the chip from the key, thanks
    Hi Phil. How did you go with the immo box?
    Aug 2007
    Front grille filler panel?? posted to brizzy??
    Alba European
    Sep 2006
    Yeh that's what I said but you'll need the ecu since the immobiliser box won't talk to any other ecu....
