Hey Sam,
what's the length, diameter and pitch on those flywheel bolts?
Mk5 R32 75mm throttle body
Used. Looks very clean as you can see and was bought as working. Includes gasket (made by me as OEM uses o-ring).
$150
80mm to 75/70/65mm TB adapter
This is from INA and is for any 80mm inlet manifold such as SEM or IE. It’s very nicely machined and has a fitting for WMI or boost sensor. Brand new, unused.
$100
Epytec 4th gear support
4th gear is a weak point in the 02M and this brace helps prevent the gears separating. Brand new, unused.
$180
(Usually $246 + shipping from Epytec)
Epytec gearbox support brace
Fixes to the end of the gearbox casing as a brace. Brand new, unused. It's the item on the left in the image. Comes with bolts etc.
$25
(Usually $40 + shipping from Epytec)
ARP crown wheel bolts
Needed for fitting an aftermarket diff such as Wavetrac. Brand new, unused.
$120
(Usually $150 + shipping from JEGS)
ARP flywheel bolts
The commonly used 156-2801 5.0 Ford bolts. They were purely removed from the packaging to measure but never fitted or torqued.
$50
K&N RE-0880
Specs are here but essentially it's a massive 4"/100mm filter. Brand new, unused.
$90
'02 S3 & '09 R36 Wagon
Hey Sam,
Hi Sam
You may know me... i am eyeing off that TB adaptor...
Hah gimme a shout mate![]()
Bump...
