Results 1 to 6 of 6
Thread: 02M & Misc Performance Parts
    Apr 2011
    Mk5 R32 75mm throttle body
    Used. Looks very clean as you can see and was bought as working. Includes gasket (made by me as OEM uses o-ring).
    $150
    80mm to 75/70/65mm TB adapter
    This is from INA and is for any 80mm inlet manifold such as SEM or IE. It’s very nicely machined and has a fitting for WMI or boost sensor. Brand new, unused.
    $100
    Epytec 4th gear support
    4th gear is a weak point in the 02M and this brace helps prevent the gears separating. Brand new, unused.
    $180
    (Usually $246 + shipping from Epytec)
    Epytec gearbox support brace
    Fixes to the end of the gearbox casing as a brace. Brand new, unused. It's the item on the left in the image. Comes with bolts etc.
    $25
    (Usually $40 + shipping from Epytec)
    ARP crown wheel bolts
    Needed for fitting an aftermarket diff such as Wavetrac. Brand new, unused.
    $120
    (Usually $150 + shipping from JEGS)
    ARP flywheel bolts
    The commonly used 156-2801 5.0 Ford bolts. They were purely removed from the packaging to measure but never fitted or torqued.
    $50
    K&N RE-0880
    Specs are here but essentially it's a massive 4"/100mm filter. Brand new, unused.
    $90
    '02 S3 & '09 R36 Wagon
    Hey Sam,
    what's the length, diameter and pitch on those flywheel bolts?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Apr 2011
    Hey Sam,
    They're M10x1 and 24.765mm long under the head.
    May 2015
    Hi Sam
    You may know me... i am eyeing off that TB adaptor...
    Apr 2011
    Hah gimme a shout mate
    Apr 2011
    Bump...
